PXI
PXI PROFIBUS Master/Slave Interface
I have found this product on ni.com, and I want to integrate this in a test system, which is based on LabWindows/CVI. Are there support libraries for CVI?
(4,700 Views)
Thank you for using National Instruments forum.
There is a driver for C-based programming language for the PCI/PXI boards, not for CVI.
That is supported by Comsoft company only and not tested with CVI.
Hope that helps.
Julien De Freitas
Applications Engineering Group Leader / Certified LabVIEW Developer (CLD)
National Instruments Switzerland
(4,685 Views)
