PXI
PXI RT Target doesn't boot correct
I have a PXI Rt Target with a PXI 8176 RT Controller. The only OS installed is the RTOS. The problem is, that the system does not finish to boot, when it is connected to the Host. I need to disconnect it (plug off the crosover cable), then boot the RT target and after I can reconnect the cable. What could be the reason?
(3,169 Views)
whats the last thing that is displayed if you connect a screen to the RT controller?
Maybe you are having problems during the network configuration.
Please give me some more information about how this problem occured first and which software versions are installed on the controller and the host PC.
regards
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(3,141 Views)
