11-14-2006 12:14 PM
11-15-2006 11:02 PM
12-18-2008 12:49 AM
HI DAQ Dude,
I'm curious to know if you solved your problem, as I'm having the same type of issue where the code runs fine in the development environment, but start and then freezes as a RT start up?
Any help would be great.
Greg
12-19-2008 10:07 AM
Hi GregY,
Welcome to the forums! Do you have the same specs as DAQ Dude? Also, can you give more details about the problem? Can you discuss what debugging steps you have conducted?
12-19-2008 11:52 AM
Hello GregY,
I struggled with this problem under 8.2, but after upgrading to LV RT 8.5.1 it seemed much better. The PXI still locks up occassionally after running for several days,but I doubt this is related. (My feeling is that the remaining problems may have something to do with memory fragmentation, or perhaps a small memory leak that eventually starves out my application -- although this is purely speculation on my part.)
While I have recently installed LV 8.6 on my test PC, I still haven't made the jump to 8.6 for the PXI, so I can't comment on whether this is better still than 8.5.1. As it stands, version 8.5.1 runs reasonably well and we have a field installation based on 8.5.1, so I guess we are waiting for a compelling reason to migrate up to 8.6. (We have been burned in the upgrade process before, so if you have something that works adequately well, you learn to live with the minor quirks.)
To summarize, I guess my advice to you would be this: If you are still running LV RT 8.2, try upgrading to 8.5.1 or perhaps 8.6 and see if that solves your problems. If you are unable to upgrade at this time, I apologize that I have nothing more useful to offer.
D.
