PXI
PXI SMU measurement using triggering waveform
I am having trouble programming a PXI 1078 with multiple NI4145 SMU's with a trigger waveform from an EXFO tunable laser output.  The laser outputs a trigger trace correlating to each step of the tunable laser as it scans wavelength.  I am using one NI4145 as the trigger input.  THe trigger signal is a 10 KHz, 2 volt, 100 us period.  I want to use another NI4145 to apply a 2 volt bias and read the current at each trigger pulse.  I will attach the trigger signal and the Labview vi I have so far.  I have tried many variations and still cannot seem to get this right.  Any ideas will be appreciated.
Message 1 of 1
(920 Views)
