PXI
PXI configuration first time
Hi everyone
I was working with RT target ( PXI) and by mistakes we have removed/deleted some folders which I think includes ethernet as well, now we are unbale to communicate with target? what we can do ?
how I set up the device again as everything was preinstalled on device?
thanks
(5,296 Views)
Accepted by topic author EricMgNiBh
Hello EricMgNiBh,
Do you happen to know which files you delete? Did you delete these files through ftp? One option is to first verify if you can see the device in Measurement and Automation Explorer, format the Real time target, and reinstall the software. If you are completely unable to communicate with the device and have exhausted any networking troubleshooting steps another option would be to create a Real Time Disk Utility USB Drive from your development machine and format the PXI system. This knowledge base walks through how to create the Real-Time Disk Utility and how to format and reinstall Real Time to the system.
Wear
Product Support Engineer
(5,277 Views)
