PXI
PXI controller
Hey,
i want to assemble a TestSystem with NI hardware.
I started with a PXI/SCXI chassis, but stumbled into PXIe chassis (compatible with PXI,  because of NI recomandations) and started configuring(shopping wizard) this system with  Ao module, etc; but suddenly, a popup appeared that i had to add a controller ??? Is this (4000 Euro controller) realy necessary ??? Can I not use a standard 700 Euro MS W7/8 PC ?
thanks.
(5,597 Views)
Accepted by topic author kdCMC
Of course you can use a standard pc. For connecting to the chassis, you have several options.
http://sine.ni.com/np/app/main/p/bot/no/ap/pxictrl/lang/en/pg/1/sn/n25:controller,n24:PXI-FSLASH-Com...
(5,585 Views)
Hello kdCMC,
As Dennis noted, a MXI link with a PC could also be a good solution (depending on your needs).
Also don't hesitate to call into your local office (see ni.com/contact) to discuss multiple solutions with my technical sales colleagues.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,569 Views)
Thierry makes a good point about contacting your local Sales Engineer and one I should have mentioned. There are advantages/disadvantages with embedded versus remote that should be discussed before you commit to a purchase.
(5,554 Views)
