PXI
PXI ground
Hello
On the DIO96 channels, the GND in the connectors is not connected to the metal casing of the board.
However of the one that puts the card in a PXI 1073, it connects the GND to the ground.
Is it possible to remove this link in the PXI?
A rider to remove for example?
Thank you in advance.
(2,666 Views)
What product precisely do you use ? And what do you want to do ?
Kardio
(2,618 Views)
I have a NI PXI 1033 chassis and when I put a NI PXI-6509 in it, it connects its GND to PXI power ground. This is not common as demand but I want to know if we can disassociate the GND from the 6509 to ground chassis knowing that I will read it further with a resistance.
(2,607 Views)
