PXI
PXI --> PXIe --> PXI
under "PXI Controllers" I can only find PXIe Controllers.
Does it mean that I can use the PXIe Controllers in PXIe as well as in PXI chassis (as the old PXI-1031)?
Thank you
(1,445 Views)
No.  PXIe is a different standard than PXI.  For a little while, there was a PXI hybrid standard that allowed PXI cards to work in PXIe chassis.  But there was never a way to go the other way around.  PXI itself is getting harder to find.  PXIe has pretty much replaced PXI.
(1,437 Views)
The reason you see only PXIe controllers would be because all the PXI controllers are now obsolete and you cannot purchase them anymore from NI.
For any obsolete NI hardware, there are a few third-party vendors who stock up obsolete HW and sell them (apexwaves, artisantg, electrorent are some)
Santhosh
Soliton Technologies
(1,428 Views)
Thanks a lot, I suspected that (but was hoping 🙄)
(1,419 Views)
Thanks a lot, also for the sources.
(1,418 Views)
