03-10-2005 04:18 PM
03-11-2005 02:18 PM
03-14-2005
11:13 AM
- last edited on
05-13-2024
11:41 AM
by
Content Cleaner
menchar,
I can only think of two types of boards we make which use the local bus:
The PXI R Series boards (also known as the FPGA boards) can route triggers to the local bus lines.
When using a DMM to control a SCXI switch in a PXI/SCXI combo chassis, triggers can be passed between the two on the local bus lines. However, this is very specific to this application and cannot be used for other purposes.
Hope this helps out, have a good day!
Ross C
