PXI
PXI modules not detected in PXIe 1082 / PXIe 8135
I have a PXIe 1082 / PXIe 8135 that has been unused for a while, it has been left without any modules in, has been powered up now and then to update Win 10 & NI software to the latest versions.
Now when I try to use the system again, it does not detect PXI modules inserted in hybrid slots. It does detect PXIe modules. I can not see PXI modules neither in the Win device manager, nor in NI-Max. I have tried several different modules like 4461, 4071, 4132...
Chassis firmware 15.0.0f0
Controller firmware 1.2.0f0
Tried:
Reset the Ni Max configuration.
Re-installed the Ni Daqmx.
Does anyone have any good idea on how to get it working?
(2,289 Views)
Bumping this one.
- PXIe modules are detected but not PXI modules.
- PXI modules not seen in Windows device manager or NI-Max
- Controller and Chassis both pass self test in NI-Max
- NI configuration has been reset.
- Entire NI software environment uninstalled, except the Package manager.
Still no PXI modules detected. I have verified with several PXI modules, checking them also in another PXI mainframe.
I don't have another PXIe mainframe or PXIe controller available to cross-check with....
Any clues out there? Is it
- PXIe controller
- PXIe mainframe
- Software
How can I proceed?
(2,222 Views)
