PXI
PXI or CRIO differential analog output modules
Does NI have any differential analog output boards or do you just have to use two channels to create the differential signal?
(6,208 Views)
Hello craiguno,
What do you mean when you say differential analog output boards? Could yo tell me more about your application or what are your requirements?
Regards
Ernesto
(6,190 Views)
I would like to provide a 200 mv (+/- 100 mv) differential signal to a differential voltage input.
(6,184 Views)
Hello craiguno,
If I am understanding correctly this might be what you are looking for:
NI BNC-2120
https://www.ni.com/en-us/support/model.bnc-2120.html
and here is the specification manual:
https://www.ni.com/docs/en-US/bundle/bnc-2120-getting-started/resource/372123d.pdf
Please take a look at page 9 where you can see the Using of Function Generator.
Regards.
Ernesto.
(6,167 Views)
Anyone else looking for information on the topic:
https://forums.ni.com/t5/Multifunction-DAQ/differential-analog-outputs/td-p/875765
(5,471 Views)
