PXI
PXI real-time target error after install / unistall software from host PC
hi,
I got the following error after install/uninstall software from host PC. how to fix this error.
Error loading 'niDAQmxRemoteService.dll' : missing export 'EtsGetickCount64' from 'ETSAPI.dll'
Error loading 'NIPALP.dll' : missing export 'EtsGetickCount64' from 'ETSAPI.dll'
LabVIEW RT 9.0 on target
and i was installing software from host PC having DAQmx 16 .
thank you
(3,065 Views)
Hey,
This error could be due to some compatibility issues between LabVIEW RT 9.0 and DAQmx 16.0. I think a good first step would be try and download the version of LabVIEW Real-Time that is compatible with DAQmx 16.0, or you can download the version of DAQmx that is compatible with LabVIEW RT 9.0. I am providing a link that lays out the compatibility between LabVIEW and DAQmx. Let me know if this helps in any way!
Link: NI-DAQmx and LabVIEW Compatibility
https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
Shezaan Noorani
(2,986 Views)
