PXI
PXI support FPGA In Parallel
Hi all,Do you  know A PXI chassis supports a maximum of several FPGA boards running in parallel, that is to say, there is a controller(PXIe-8881) as the master node deployment simulink controller model, n FPGA(PXIe-7868) as the slave node deployment circuit model, how is the signal bandwidth distribution of their self-check, how to calculate the delay caused?
(1,910 Views)
It depends on how the data are being sent and received between different FPGA targets. When you use Open FPGA VI Ref and read/write via either FIFO or I/O Node, the data are processed and pass thru the controller. The lowest latency is implemented using Peer-to-Peer Streaming. The model of the chassis and the location of the module in the chassis have an impact on the bandwidth.
https://tmesystems.net/
(1,874 Views)
So far PXIe-1095 seems to be the best with 24GB/s throughput (even across other PXI manufacturers)
Santhosh
Soliton Technologies
(1,830 Views)
In addition some cards have multi-gigabit transceivers (MGT) which allow for direct communications between NI FPGA cards.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,821 Views)
Thanks,that's very help!
(1,780 Views)
