05-28-2010 08:54 AM
PC doesn't see the PXI system. When I tried to install the service platform for chassis and controller ver 2.5. A message states that a higher version is already installed.
06-01-2010 10:55 AM
Hi Gordoo3,
Can you expand on the hardware you are using (Chassis, Controller, Devices, etc.)? Do you have a MXI connection to your PC? Have you identified the chassis in MAX? Here is a Knowledgebase article that describes this process.
Best,
