PXI
PXI with EtherCAT Motor control and FPGA
Hello together,
I own a PXI 1078 connected to a EtherCAT Expansion Chassis NI 9145. The expansion chassis will be used to implement FPGA I/O. At the same time, we want to control a Kollmorgen AKD drive.
My question is: if I put the ethercat expansion chassis in FPGA mode, how are the data transmitted to & back to the PXI? Can I still communicate with the motor drive or does the whole system have to be in Scan mode?
Lysandros
(3,601 Views)
Hello Lysandros89
it depends on your implementation
Programming the FPGA on an NI EtherCAT Expansion Chassis
Programming EtherCAT I/O With FPGA Intelligence
A simple way are user defined variables on the FPGA and use the EhterCAT implementation in parallel with this.
best regards
Alexander
(3,559 Views)
Hello Alexander,
thanks for the links and the advice. I am realizing that by using the Ethercat bus, I am loosing the advantage of the backpane synchronization which is offered with PXI. Would you recommend adding I/O and FPGA cards into the PXI 1078 and running everything there instead of going with remote expansion chassis like the NI-9145?
Best regards
Lysandros
(3,549 Views)
Accepted by topic author Lysandros
Hello Lysandros89,
if this is possible yes, because of better performance an access to the I/Os.
best regards
Alexander
(3,541 Views)
