PXI
PXI4461 error on PXIe1078 chassis
hello all,
I have used PXI4461 on PXIe1078 chassis and found error in MAX, the PC OS is Win10 64bits installed PCIe8361 communicated with PXIe8360.
the symptom and NI SW installed in attached files
have tried these before.
- Remove NI software and reinstall ==> result is same
- reset NI DB ==> result is same
- Reset OS (PC windows) ==> result is same.
Any guidance would be appreciated
GR,
Message 1 of 1
(1,892 Views)
