PXI
PXI6341/SCB68
Hi guys, I have a question about the SCB68. When I used Digital Output DAQMX task, voltage continues to flow through the pins. Is there a problem?
(903 Views)
Can you elaborate more on your problem description?
Which pins have the voltage? How do know there is a voltage? Do you measure using DMM? Can you provide the wiring diagram of your setup?
https://tmesystems.net/
(859 Views)
Actually I found this is normal situation. I have another situation. How can VeriStand see the remote machine (PXIe8101)? I added on the machine in the System Explorer menu but Veristand doesn't see the channels, even if I arrange the NI MAX. How can I use the remote systems remote systems?
(829 Views)
