PXI
PXI64HANG
NI posted the following warnings earlier this year but did not provide any details about the symptoms of this hang.
Possible System Hang with Third Party PXI Modules for some NI PXI Systems with a 64-bit Operating System
http://digital.ni.com/public.nsf/websearch/85A51FFABE5C17F886257995001AF369?opendocument&Submitted&&...
Product Notification: Possible System Hang with Third-Party PXI Modules
http://digital.ni.com/manuals.nsf/websearch/6C2BC403421708B5862579BF006E2D0B
Would this produce a warning in LabVIEW, a Windows pop-up, or a system crash? Would this error occur in the background or only during instrument communication? Would this cause other LabVIEW or TestStand processes to hang or just PXI communcation?
I don't want to take production systems down for a driver upgrade if it's not necessary. So I would appreciate the feedback of anyone that has experienced this issue first hand.
Thanks!!!
Sam Broyles
Staff Test Engineer
INOVA Geophysical
(5,563 Views)
Hi Sam,
From what I read at the link that you posted, there is a possibility for a system crash, when a PXI-1 or hybrid-compatible PXI module attempts 64-bit memory addressing transactions with the listed chassis. I believe this is irrespective of what Application Development Environment (ADE) that you use. If you believe your system is vulnerable to this problem, I would recommend the driver upgrade.
Tunde S.
(5,527 Views)
Tunde,
I have not seen a system crash, but I would like to know if this problem could produce more subtle symptoms. For example, could background communication to the PXI cause other LabVIEW/TestStand operations to be interrupted or delayed? Or would this be limited to LabVIEW/TestStand operations that perform measurements with a PXI instrument.
Thanks!!!
Sam Broyles
Staff Test Engineer
INOVA Geophysical
(5,520 Views)
Accepted by topic author sam.broyles
Sam,
If you trigger this problem it's not subtle.  It will stop communication to anything in the PXI chassis, which bluescreens or hangs the system (assuming you are using something in the chassis).  It doesn't happen every time there's a 64-bit address on the bus, but when it does you'll have a hard time missing it.
- Robert
(5,506 Views)
Thanks Robert,
That is the detail I wanted to see. I have yet to see a blue screen or loose communication with the chassis.
Sam Broyles
Staff Test Engineer
INOVA Geophysical
(5,502 Views)
