PXI
PXI8336, need to cycle power on cPCI w/o losing link.
 I need to be able to cycle power to my cPCI chassis in order to test a PMC board.  I am constructing a test system.  So, rebooting
at the end of each board test is not acceptable.  When power is cycled, the optical link shuts down and will not restart.
Thanks, in advance, for the help on this.
>>Eric
(3,087 Views)
Because the BIOS determines what resources are needed by looking at the PCI bus and then allocates them at startup, disabling this connection could cause random problems (possible blue screens) and is not supported by NI.
Thank you
(3,071 Views)
