PXI
PXI8840 Unable to access I-connect
Hello, experts.
Now I open the 8840 controller, but I can't access the system, and the following message appears. What should I do
MAX system identification name: NI-PXIe8840-2F320A82LabUIEW Real-Time Single-Core Kernel found '2' CPU coresConsider installing NI RT Extensions for SMP (MultiCore Support) module from MAX
Initializing network..
(1,226 Views)
The PXI controller is running Pharlap RTOS now. You use another host PC to detect and connect to it. See Getting Started with the LabVIEW Real-Time Module
https://tmesystems.net/
(1,200 Views)
