PXI
PXIE 5451 detection issue once in a hour in my PXIE-1065 Chassis
HI All,
We are using PXIE-1065 chassis and NI-PXIE 5451 AWG generator for our test bench.
In that we are facing 5451 card detection issue once in a hour. If i see in NI MAX it is not showing also LED is turned off.
If i restarted the chassis it is Working fine.
Please suggest me a solution to solve this issue.
(2,239 Views)
Umm... Which FAN state is? "Auto"? "HIGH"?
 When you use AWG device, you should set the switch to "HIGH".
I guess the cause is the board temperature.
Certified LabVIEW Developer
GCentral
(2,219 Views)
