PXI
PXIE-8880 Link Configuration
Is it possible (How?) to force the controllers "Link Configuration" to x4, x4, x4, x4?
See p A-1 in "NI PXIe-8880 User Manual"
(3,859 Views)
I think there is nothing to configure, the manual states that the link config for PXIe4 link config is x4
Santhosh
Soliton Technologies
(3,835 Views)
Maybe I am misinterpreting but the manual states (p A-1 doc mentioned above):
PXIE Express 4 Link Configuration x4, x4, x4, x4
PXIE Express 2 Link Configuration x8, x16.
In BIOS I can see two "Links", I want to force the controller to use the 4 Link configuration of the IF.
(3,819 Views)
It's dependent on the PXIe chassis the 8880 is installed in. All PXIe chassis that I know of are either 2 link or 4 link. The controller can switch between a 2 link and 4 link to make it compatible with all PXIe chassis.
For example:
The 1088 is a four link chassis. Meaning, there are four x4 links to the controller slot. So in this chassis, the 8880 would configure itself to connect with four x4s.
The 1095 is a two link chassis with a x8 and x16 link to the controller slot. The 8880 will connect with a x8 and x16 connection when used in this chassis.
In the end, you cannot force the controller to have a four x4 links when the chassis only has two links.
(3,769 Views)
Ok, thanks for replies.
The backplane is a custom with a topology closer to the 1088 chassis. An older 8135-controller identifies the three connected peripherals but the 8880-controller configures itself into 2-links mode, which leaves one peripheral unusable.
(3,763 Views)
Accepted by topic author Bitdiddler
The problem was related to the backplane id/conf-EEPROM and its content.
(3,749 Views)
