PXI
PXIEe-1085 control of PCIe card
We have a PXIe-1085 chassis with a PXIe-8135 embedded controller and are looking at a third party peripheral card that only comes in a PCIe form factor.  I understand that the bus structure is very similar, so communication is not likely to be a problem, but I'd like confirmation in two areas:
1) Is there an adapter to allow the PCIe card to interface with the PXIe 1085 chassis?
2) Is full PCIe bus functionality available from the PXIe-8135 controller across this hardware adapter?
Thanks.
(4,278 Views)
National Instruments doesn't make those adapters. You might be able to track one down but it'd be from a 3rd party.
(4,253 Views)
