PXI
PXIe-1065 not detected by MAX.
I am using NI PXIe-ExpressCard8360. I see the Express card listed under "Devices and Interfaces". But the chassis is not detected. I could not find the 1065 in the list when I tried to add the chassis manually.
(5,688 Views)
Hi nharshiin,
What OS are you using? Which PCI/PCIe device is in your computer? Do you turn on the chassis before turning on your computer?
Could you post a screenshot of your MAX's Devices and Interfaces window to understand a bit better what you are seeing?
Thanks!
Xavier
(5,667 Views)
Hi xavvvv,
I was turning on the chassis after turning on the computer. The chassis has to be turned on before the computer and that fixed the issue!
Thanks!
(5,656 Views)
