PXI
PXIe 1075
Hello everybody,
Could any of you suggest to  me what it might be the problem.
We Have Two chassis, one for VSGs (contain the controller) and One for VSAs.
  1. I realized that on the second Chassis (Receivers' chassis) is not read the (speed of the fan, the voltage, the temperature )  correctly , I mean when I increased or decrease it, the speed of the Fan for example , it is not updated on the screen while for the other chassis (Generators' chassis) it works correctly .
  2. The  other one which I got, that the second Chassis (Receivers' chassis) turn off suddenly and the indicator becomes red as shown in the attached picture.
with all the problem above, the NI-MAX configuration is messed up, I attached two pictures to compare between the normal case and when the problem happened.please see the attached pictures.
I need your suggestion about what it could be the problem, Is it the Chassis? Is it the receivers? Is it the MXI ?
Thank you in advance for your attention
best regards
Message 1 of 1
(2,756 Views)
