PXI
PXIe 1082 firmware update fails
Hello
I just fried a 1062Q backplane but by chance had a 1082 backplane on the shelf.
in NIMax, the backplane firmware shows up as version 1.0.0f0, and hardware rev A.
Running ver 17 of "everythig", NIMAX, PXI platform services.
Controller PXIe-8135, Win10.
The 1082 is identified and passes NIMax self test.
Only the first temperature sensor returns a reasonable value.
But opening the VISA test panel fires:
Error opening resource:
{B63C26E6-6E77-4A84-BFD4-3B0F3D8F70D9}
VISA: (Hex 0xBFFF0012) Invalid resource reference specified. Parsing error.
I'm trying to update the firmware via MAX PXIe-1082_fw_15_0_0f0.bin but that fails with the message .
"There was a problem updating the firmware for this device"
Any advice here on how I can update the firmware?
thanks
(3,542 Views)
I forgot to mention that the power supply/chassis where the PXIe 1082 backplane is mounted,
is originally a PXIe 1062Q, in case that matters...
(3,526 Views)
Accepted by topic author janaf
Hi janaf,
Try running NI MAX as an administrator, as mentioned in the KB below.
http://ae.natinst.com/public.nsf/web/searchinternal/fae11701fcda6c7b8625807a007a5fd4?OpenDocument
Jack
(3,444 Views)
That did it!
Kudos!
(3,416 Views)
