10-05-2022 02:42 PM
Can the PXIe-1088 mounted in the vertical orientation. I can't find anything in the documentation dictating horizontal mounting requirements.
Solved! Go to Solution.
10-05-2022 03:26 PM
I don't see a reason why mounting orientation would matter for the PXIe chassis or any instrumentation, everything is solid state (fans don't matter).
10-06-2022 10:35 AM
My biggest questions was around if the forced airflow was accounting on a horizontal orientation and if the operation shock/vibration spec was only rated in specific orientations. The datasheet doesn't specially call it out either way.
10-06-2022 10:46 AM
If those are critical concerns for your application, it is best to reach out to NI Tech support for an official answer. Since there is no warning about mounting in other orientations, I would assume the specifications apply irrespective of the orientation.
10-12-2022 08:03 PM
We reached out to NI and they said there should be no issues if we maintain the proper clearances.
