PXI
PXIe 4082 Sensitivity measurments
I am trying to determine the sensitivity (minimum value instrument can measure) for Resistance and Inductance measurements for the PXIe 4082.
Here is the spec sheet
https://www.ni.com/docs/en-US/bundle/pxie-4082-specs/page/specs.html
It lists the minimum range but not the sensitivity.
Dan Shangraw, P.E.
(4,562 Views)
I'm not sure if I'm understanding your question correctly.  When you say sensitivity for resistance are you saying Ohm/volt sensitivity?  You may want to take a look at the spec overview for the PXIe-4082 sensitivity:
https://www.ni.com/en-us/shop/model/pxie-4082.html
And a couple more additional resource below:
https://www.ni.com/en/shop/electronic-test-instrumentation/digital-multimeters/dmm-measurement-funda...
http://www.allaboutcircuits.com/textbook/direct-current/chpt-8/voltmeter-impact-measured-circuit/
Jonathan R.
Applications Engineer
(4,523 Views)
Hello Jonathan,
I am looking for the sensitivity
2. Sensitivity
Sensitivity is the smallest unit of a given parameter that can be meaningfully detected with the instrument when used under reasonable conditions. For example, assume the sensitivity of a DMM in the volts function is 100 nV. With this sensitivity, the DMM can detect a 100 nV change in the input voltage.
Where or how can you determine this value for the PXIe 4082
I am looking at resistance and inductance measurements
Dan Shangraw, P.E.
(4,521 Views)
I just realized that you posted this on the incorrect forum.  You may have better luck here.  Regarding an answer to your question this isn't so straightforward and I would suggest you create a service request with us if you have a service agreement.  I'll try to look into this a little deeper but I think you'll get additional hits on your post if you post this in the correct forum post.
Jonathan R.
(4,503 Views)
OK I created a service request.
I will post my answer when I get a response.
Dan Shangraw, P.E.
(4,494 Views)
(4,490 Views)
