PXI
PXIe 4139 slew rates
Does the PXIe 4139 card have the capability to control the ramp up/down of the voltage and current? For example, to start at 100mA and ramp down to 0mA at a rate of 18 A/s.
Thanks.
(3,923 Views)
As far as I have used the 4139, it has a programmable output resistance but no control over slew rate whatsoever.
Santhosh
Soliton Technologies
(3,406 Views)
Is there a specific vi/driver that would be used to program the output? And if so, what is it?
(3,208 Views)
You can use the property node with typical niDCPower programming to set the output resistance
Santhosh
(2,442 Views)
