PXI
PXIe 4140 Current AutoRanging
I`m having some problems with current ranging on the PXI 4140 cards. I am sweeping voltage from -6V to 6V and i have set the niDCPower property node to AutoRange current but when i set the current limit it seems to fix the current range rather than autoranging.
For example,
10uA current limit the current range is set to the +100nA to 10uA
100uA current limit the current range is set to the +1uA to 100uA
1mA current limit the current range is set to the +10uA to 1mA
I was hoping that by setting a current limit of 1mA would mean that the current would autorange to the lowest current possible and then limit at 1mA. So in the image below from -6V to 0V in the 1mA range would measure the same as the blue line rather than the higher values as measured and shown in the grey lines.
Autoranging issue
Am i missing something in the settings?
James
Message 1 of 1
(3,046 Views)
