PXI
PXIe-4339 with RM-4339 - Quarter Bridge Wiring Advice
I want to connect three wire strain gauges to our PXIe-4339 and RM-4339 terminal. I'm trying to figure out an efficient way to do this.
The PXIe-4339 manual indicates that all connections are made on the transducer side. Is this information correct? With our previous SCXI-1314 terminal block, I typically made connections by jumping wires internally within the block. For instance, one wire from the strain gauge would connect to EX+, another to AI+, and the third to QTR, and then I would bridge the shunt inside the block.
Here's the diagram:
I considered connecting the strain gauges to a screw terminal block, completing all the necessary connections there, and then linking them to the RM-4339. However, I'm exploring alternative solutions for a more streamlined approach, especially since I'll be connecting approximately 200 strain gauges.
Message 1 of 1
(1,450 Views)
