PXI
PXIe-4339 without RM or TB 4339?
Hi-
does anyone know how to use a PXIe-4339 without the NI terminal block or rack mount breakout?
We know how we want to connect our bridges, and would like to make our own custom breakout to suit our transducers and connectors. However, the presence of the RSVD comms pins, with ICs evident on NI's PCB layout, and the automatic recognition of attached NI "accessories" by MAX, and a little experiment, suggests the RSVD connections are required for NI-DAQmx to be happy.
Has anyone worked around this? Is there a default bridge configuration that will work without any comms? The documentation we've found has been... lacking...!
Many thanks...
Message 1 of 1
(384 Views)
