PXI
PXIe-5186 error code -233401
Getting 'internal hardware error' in MAX on a digitizer I have been using almost every day for almost a year without issue. Tried rebooting computer, PXI, removing digitizer and reinstalling, reinstalling NI-SCOPE, etc. to no avail. I recently changed LabVIEW versions from 32-bit to 62-bit to increase memory available to LabVIEW, though I'm not sure how that could cause an 'internal hardware error'.
Does anyone know what this error code means and how I can go about fixing it?
Brad
(2,589 Views)
Accepted by topic author itst1357
"internal hardware error" means that something is messed up at the HW level within the instrument and it may not recover. If you have already tried, reset, self-test, self-calibrate and the instrument did not recover, your only option is to send the HW to NI for repair.
Upgrading to 64-bit LV has nothing to with the error you're facing.
Santhosh
Soliton Technologies
(2,544 Views)
Hi Santo,
Great. Thanks for the response. I have already submitted a service request but I thought as a last ditch effort someone might have a solution.
(2,541 Views)
Update: the issue was a 12 V power supply in the PXIe-1078 chassis. After a few weeks (and an RMA for the PXIe-5186 that didn't solve anything), the chassis fan stopped spinning, so I sent it in for RMA and a new power supply it solved all the issues I had been having.
(2,357 Views)
