PXI
PXIe-5450 An Internal error occured, error # -1074106671
We have an PXIe-5450 on chassi 1062Q.  when we initialize the board, we got error -1074106671 (an internal error occured). Anyone know how to fix this error? we're really appreciated your help. By the way, we are using Labview 2010 and NI-FGEN 2.9
(4,647 Views)
Hello Milpitas,
Can you please provide more information regarding the issue: Which is the chassis you are using? Since when this error is showing up? Was the card working perfectly? What kind of measurements is/was the card performing? Can you see your card on NI-MAX? Where you able to see it before the error message?. Also if you have more information about it I'll appreciate your comments, Have a wonderful day.
Luis Garcia
(4,608 Views)
Hi Luis,
We are using the chassis 1062Q.  We saw the card on NI-MAx and it is working properly. when we initialize with nifgen, we see the error. Please see the attached image for the error and the ni-max. Thanks.
(4,601 Views)
Can you please also attach a screenshot of the software bullet on NI MAX, I noticed that this error message happens when you try to run a VI, Is it an example of LabVIEW or created it? Please attach the VI also. What LabVIEW version are you using. In MAX you can run the visa test panel, what happens when you run this option, please attach an image of that too. Have a nice day.
Luis Garcia
(4,542 Views)
