PXI
PXIe-5450 error messages - Error (-239101) and Error (-239100)
Hi!
Our PXIe-5450 is giving us a couple of error messages.  The error codes are -239101 and -239100.  The first says "Internal Hardware Error occurred in MiG Hardware".  The second one says "error at niFgen Initiate generation".
This is PXIe-5450 is housed in a PXIe-1075 chassis, together with another PXIe-5450.  Both are managed by a PXIe-8130 (also housed in the same chassis).  The second 5450 is not giving any problem and working fine.
Any suggestions on what the problem is and how to solve this?  Thanks!
(2,874 Views)
Hello!
I looked internally through our database on similar issues and wasn't able to find too much for me to single out the cause of your issue.
Are you able to pass a self-test for the device?
Can you delete the device from MAX and then reinsert the card to get it recognized again?
Has this card ever worked for you?
Are you getting this error in the soft front panel?
-Ryan
(2,815 Views)
