PXI
PXIe-5451
I want to do some test by using PXIe-5451 AWG, and my 5451 AWG is in Remote Systems. However, I can not change the output frequency of 5451 AWG when I use the Test Panels. As u know, FGEN can not be used in Remote Syestmes. So, what can I do..
Thanks.
Vincent
(6,478 Views)
Hi Vincentum,
As this KnowledgeBase arcticle confirms, there isn't a way to use FGEN SFP on a Real-Time systems.  In order to control the output frequency you will need have a target for the 5451 in a Real-Time project, then create a VI under this target and use the FGEN palette functions to achieve this functionality.
(6,437 Views)
Hi matt
    Thank you very much for your nice reply. Now, I want to ask that can I change the output signal resolution of AWG PXIe-5451 when I create my VI in a Real-Time project. As you know, it is a 16-bit AWG, now I just want to use the about 12bit resolution signal generation.
Vincent
(5,521 Views)
Hello Vincent,
According to the Signal Generators help manual, the NI PXIe-5451 stores arbitrary waveforms in memory as signed 16-bit digital words. On the NI PXIe-5451, the entire 16 bits are sent to the digital gain circuit, the OSP and the DAC.
http://zone.ni.com/reference/en-XX/help/370524P-01/siggenhelp/5451_ni_5421_sample_size_and_resolutio...
May I ask why you are wanting to reduce the resolution of your output signal?
Best,
(5,509 Views)
Hi  Anderson,
Thank you for your kindly reply. I am doing some contrast measurement by using some signal with different resolution. So, I want to know if I can use this NI PXIe-5451 AWG to generate the different resolution output signal.
Best Regards,
Vincent
(5,474 Views)
Vincentum,
The AWG will always represent the data using 16-bit words, but you may be able to manipulate the data yourself to appear as less resolution (for example, take your data set and round values to the nearest X).
Jon F.
Technical Support Engineer
(5,455 Views)
