PXI
PXIe-5624 IF Digitizer Module Calibration Question
My team has been using the PXIe‑5668 Vector Signal Analyzer and ran into issues with its 5624 IF Digitizer Module. This part will be shipped back to NI in order to get repaired, however, the turn around time is 2 to 3 months. In the meantime, we were planning on buying another 5624 IF Digitizer Module while waiting on our old module to be repaired. My question is - does the 5624 IF Digitizer Module need to be calibrated with the rest of the PXIe‑5668 Vector Signal Analyzer set in order to run properly or can we simply just replace the IF Digitizer Module and begin testing again?
Message 1 of 1
(498 Views)
