PXI
PXIe-5665 max base band signal bandwidth.
Hi
Where I work, we have available a PXIe-5665 (14Ghz version) for RF analisys. I wonder if we can measure and decode correctly a QPSK signal al 8Ghz, with a channel BW of 180Mhz (base band bandwidth for 99% of transmitted power). This signal transmit 120 MS/s.
My concern is in the Max RBW that it says at the most 50MHz  in the PXIe-5605 RF Downconverter.
I hope someone can answer me and thank you for your time.
Message 1 of 1
(800 Views)
