PXI
PXIe 5785 stopped working
Hi, I was working with a pxie 5785 board, suddenly the system stoped working and the system didnt recognized the board, please help me and give me some advice , I attached the device manager and the NI MAX image that can not recognize the board properly. Is it a driver problem? or my hardware is damaged? how can I resolve the problem?
 thank you in advance
Message 1 of 13
(2,461 Views)
Looks like the FlexRIO driver is not installed.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 2 of 13
(2,450 Views)
Thank you for your response, would you if I ask you that is it a common problem that a driver does not work suddenly? I don't know which driver is missing, I have installed all the drivers.
Message 3 of 13
(2,408 Views)
Could be PXI platform services or FlexRIO.
Could you post a screen shot of the installed items as shown in NI Package Manager here?
ALE Consultants
Message 4 of 13
(2,401 Views)
Hi, thank you for following up my problem. there are a huge number of software installed. I took a shot from flex RIO's installed drivers.
Thank you in advance for your help.
Message 5 of 13
(2,382 Views)
You need to have LabVIEW, LabVIEW FPGA, FlexRIO, and PXI Platform Services
PXI and FlexRIO must be installed after the LabVIEW parts.  Maybe you installed them not in that order.  I'd uninstall and re-install.
ALE Consultants
Message 6 of 13
(2,374 Views)
Hi. thank you for your response, I will try it.
Message 7 of 13
(2,351 Views)
Dear Terry,
Thank you very much for your help, I have done your suggestion about the order of installation but its not worked and the board is not recognized by my system. the status is as before like  the images in NI_max which I sent in my previous posts, do you have any other suggestions? does the board have any hardwired reset which can help? is there any other way which I can communicate with the board?
Iman
Message 8 of 13
(2,210 Views)
Can you post a screen shot of what you see in NI MAX?
ALE Consultants
Message 9 of 13
(2,185 Views)
Message 10 of 13
(2,173 Views)
