PXI
PXIe-6341 compatibility question with terminal block and cable
Hi, we have a PXIe-6341 in a chassis right now. I am trying to purchase a set of cables and a terminal block to use with this card.
According to PXI Advisor, I should be able to use CB-68LP (https://www.ni.com/en-us/support/model.cb-68lp.html) connector block as well as R68F-68F cable (https://www.ni.com/en-us/shop/details/product-item.187252-01.html).
I am not quite convinced that this is the case. Wouldn't you need a M-F connector like SHC68-68-EPM (https://www.ni.com/en-us/shop/details/product-item.192061-01.html)?
Thanks for your help!
Chris
(8,939 Views)
Reference: 63xx Models : DAQ Multifunction I/O Cable and Accessory Compatibility
https://tmesystems.net/
(8,907 Views)
