PXI
PXIe-6341 is not detected by NI Max
There is an issue with the PXIe-6341 module that we use for I/O in our multiphoton imaging system. Apparently, the PXIe-6341 module is not detected by the NI Max software and also the "LINK" LED in the PXI chasis (PXIe-1073) is off (only the PWR LED is green). We tried updating the NI MAX software, checking the connections of all the cables, and also connecting the PXIe-6341 to a different PCIe slot, but still could not resolve the problem. Any suggestions for fixing this issue? I have attached images showing the error messages shown in NI MAX and also an image showing the PXI chasis with only the PWR LED turned on in green.
Thanks.
Best Regards,
Dulara
(847 Views)
See MXI-Express Compatibility and Connectivity Troubleshooting Guide
https://tmesystems.net/
(816 Views)
