PXI
PXIe-7915 DRAM clock issue
HI All,
I got early access to PXIe-7915 FlexRIO module. I was provided with beta software for this device. Everything works fine except it seems that DRAM clock is dead. I instantiated DRAM and saw that reading and writing were not working properly. Then I made a counter using DRAM clock and noticed that its value was always zero. I have two pieces of this hardware and I see the same behavior on both. From this reason, I will exclude board damaging.  Maybe the issue is beta software.  Is there release version of software for this device that can be downloaded from NI website?
Thank you in advance.
(2,885 Views)
Does the beta software have any examples that use the DRAM?  There may be some subtle configuration setting that is being missed.  It could be a 'feature' of being beta so you should definitely let NI know directly.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,869 Views)
Accepted by topic author vekijag
Moving conversation to private messages. There's a strong possibility that this is a bug in the early access driver that has since been resolved.
Rob B
FlexRIO Product Manager
(2,859 Views)
