PXI
PXIe-7966R
Hi.
I have FlexRIO PXIe-7966R and i want to make Poisson random number generator with throughput 10 MS per second. Most of algorithms are using "for" and "while" cycles, but i need to generate one sample per 10 MHz cycle. Do you have any suggestion?
(3,263 Views)
You're essentially describing the exact scenario for Single-Cycle Timed Loops in LabVIEW FPGA. Check out some of these links for more info:
- Single-Cycle Timed Loop FAQ
- LV FPGA Timed Loop Help
- How Do I Implement Custom SCTL?
(3,251 Views)
