PXI
PXIe-7971R on Linux
I've installed repo ni-software-2020 on RHEL 7 system. Installed packages from it: ni-flexrio, ni-pxiplatformservices, ni-rseries.
When I'm trying to start C program which uses C API generated files I have an error "-63194". (dlsym of NiFPGA_Open is (nil) (1))
Did anyone had the same issue?
(1,999 Views)
Could you share the screenshot of the error message?
Also which version of NI software's you have installed in your PC?
(1,974 Views)
repository: ni-software-2020
(1,963 Views)
Info above.
(1,949 Views)
