PXI
PXIe-8133 vs PXI RT Controller
I am wondering what type of hardware I would need to use for a DAQ project. I have a PXIe-1075 chassis with a PXIe-8133 controller on hand but I don't have a lot of experience with with DAQ applications so I'm hoping someone here can give me some advice.
There will be 70 to 80 analog input channels being sampled at 1kHz with filtering to eliminate high frequency noise. There will also be a PID loop controlled at 5Hz and data being logged to tdms files and displayed on charts on the front panel updated at 5Hz.
Is there a good chance that the 8133 controller with LabVIEW will be able to handle the task or is this something that is likely going to need a RTOS controller? Thanks in advance.
(3,440 Views)
For the PID, it is probably best to go with an RT system.  But that really depends on how deterministic you need the PID loop to be (ie how accurate of the 5Hz do you need).
How many output channels do you need?
On the surface, I would probably just get a USB-6225 (80 AI, 2 AO) and then you can just use a good PC.
(3,434 Views)
Thanks for replying. I think I will only have a single output channel.
I was just trying to get an idea of whether the hardware I have available would have a good chance of being sufficient before I spent a lot of time writing code.
(3,415 Views)
