PXI
PXIe-8135 & PXIe-1078 hard crash on boot
Hi all, I have a problem with a PXI controller that crashes hard upon boot occasionally.
There are no memory dumps, only an assertion printout in the terminal.
It is a fairly new corei7 based controller, perhaps some timing/thread safety related issue?
Perhaps I am missing something obvious?
See the attached picture.
Br,
/Roger
(6,786 Views)
Another crash, slightly different with an ISR priority exception. See the attached image,
Br,
/Roger
(6,777 Views)
Perhaps I got it to work, now the controller seem to be booting without crashing.
However, it is worrisome that an unmodified ni-rt.ini file can cause boot order / dependency crashes.
  1. Delete the ni-rt.ini
  2. Reinstall all RT software packages.
So for people out there experiencing the same problems, try this one out and see if it helps.
Br,
/Roger
(6,735 Views)
This worked for me on my ancient PXI-8196.  Its seemed to be a side effect of upgrading the whole thing from 2011 sp1 to 2012 sp1.
Thanks!
(6,268 Views)
