PXI
PXIe-8821 Disk write speed
Need to stream data continuously from scope card to disk, sampling at 100M samples/sec.  I think the PXIe-1071 chassis is capable, but what speed can the PXIe-8821 controller write data to disk?
(3,308 Views)
it seems that it is 1,6Ghz, therefore you can do it!
(3,243 Views)
Are the samples 8 bits or higher?  If they are 8 bits, then 100 MS/s is 100MB/s.  Otherwise it is 200MB/s.
Are you acquiring multiple channels?  The numbers above need to be multiplied by the number of channels.
Are you using the disk in the PXIe-8821 controller?  Did you order it with a hard drive or solid state drive?
(3,174 Views)
16bit data, one channel at high speed, so greater than 200MB/s.
(3,172 Views)
200MB/s likely cannot be done with the 2.5" SATA hard drive option.  NI doesn't spec performance of the SSD, but the 250GB SSD option might be able to keep up.
(3,165 Views)
That is my thinking too.   Thanks.
(3,161 Views)
