PXI
PXIe-8861 Dual Channel Parameter Programming
Hello, I'm trying to write a parameter .xml file for dual channel mil std 1553 application and having trouble to deploy Pxi. Do you have any working dual channel parameter file for reference? It'ld be appreciated.
Ps: The error code is 403002.
Ps2: I cant use Labview scripting api for now.
(1,420 Views)
Your topic is misleading as 8861 is an embedded controller and conceptually it is just a PC in a different form factor.
What exact instrument or card are you dealing with?
Santhosh
Soliton Technologies
(1,398 Views)
Sorry for the misinformation, I'm working on Astronics Ballard OmniBus II PXI Express (PXIe) card.
(1,391 Views)
