PXI
PXIe-8880 UDP error
Hello everyone,
I was working with PXIe-8880 and LabVIEW 2016. I had a problem with UDP communication protocol.
My program works correctly with my PC and "Firesi FRS-RACK" protection system througth Ethernet and UDP protocol. All data transfers(requests and respones) is OK.
When i run the same program on PXIe-8880 , i don't have a response. I tried change IP adress of PXIe-8880, but thats not a solution.
As you see,  i made a new simple program with UDP squares and i still have no response.
What's wrong?
(3,001 Views)
Are you able to ping the Firesi FRS-RACK from the PXIe 8880 controller?
What if you swap the cabling between the two Ethernet ports on the controller?
Santhosh
Soliton Technologies
(2,963 Views)
problem is solved,
thank you for message
(2,953 Views)
The reason was about Firesi device, not PXI
(2,952 Views)
