PXI
PXIe DAQmx driver for centos 6
I have recently bought some PXIe 1084 / 1088 and PXIe Boards 6509 / 6220 / 6704. I need them with centos 6 environment, but I have some difficulties to find DAQmx drivers for this OS.
For test I use a windows 7 OS and Boards are correctly detected (necessiting DAQmx 20.1 installation), but nothing with the centos 6.
Is everyone knowing a way to detect PXIe Boards under Centos 6 environment ?
Many thanks for help.
(580 Views)
You can use NI Linux Device Drivers Download. However, it was never supported in RHEL/CentOS 6.
According to the attachment at the bottom of NI Hardware and Software Operating System Compatibility, it was supported in RHEL/CentOS 7 from 18.0 to 2022 Q3. For RHEL 8, 19.1 or later. For RHEL 9, 2022 Q4 or later. See Installing NI Products (Red Hat Enterprise Linux) for the installation instructions.
Once the driver is installed, use lsni to detect the hardware. If you use a recent version of the driver, you can use the Hardware Configuration Utility, a GUI tool similar to NI MAX.
https://tmesystems.net/
(561 Views)
